Torque on head bolts?
TroyR
12-29-2007 12:54:03
'39 B#25550.I'm getting ready to put my head on.I was wondering what should I torque my head bolts to?Would you put RTV on one side,both sides,or no sides of the head gasket?
Kentb of SWMO
12-30-2007 15:27:23
 Re: Torque on head bolts? in reply to TroyR, 12-29-2007 12:54:03
Be sure the threads on the head bolts are CLEAN and OILED or Anti-Siezed
Kent
old
12-29-2007 14:35:24
NO RTV silicone. But you can use the paint like the other guy says and or copper coat which is made just for head gaskets. 60 ft/lbs on the head as per the I-T manual
hillbillyOH
12-29-2007 14:11:07
I believe the torque should be 60 lbs.
The advice I was given was to spray-paint the head gasket with silver aluminum paint. Skip the permatex or RTV. If you tighten properly, it will seal just fine.
And let me tell you -- I sure appreciated this advice when I had to unexpectedly pull the head back off.
