D19 Loader
Michael Crowe (
12-27-2007 18:13:28
I would like to find out what is the best looking/performing front end loader to put on a D19D. Also would be interested in the front pump that fits between the engine and steering bolster to give it true live hydraulics. 816 898 7277. Thanks. Michael
rich4
12-28-2007 10:13:17
 Re: D19 Loader in reply to Michael Crowe (MO), 12-27-2007 18:13:28
We had a Du-all loader on our WD-45 years ago and it worked well with a hay sweep and a manure bucket, it could lift fairly high and was sturdy. I believe we used a pto driven pump, that gave it live power.
Jack a
12-28-2007 12:21:29
 Re: D19 Loader in reply to rich4, 12-28-2007 10:13:17
All WD and WD45s have "live" hydraulics from the factory. A front mounted pump would give you independent hydraulics. Your PTO driven pump would still qualify as live hydraulics only but you probably gained the ability to use competitors hydraulic cylinders.
Tfanning
12-28-2007 05:09:51
Mike, We installed a Kelley loader on our WD45 35 years ago. Initially, we used the tractor hydraulics, but subsequently we installed a front mounted pump which we obtained from Kelley. I am not saying Kelley in the best, but it does work well for our needs. Tom
