5015 A/C engine parts
Southern4020
12-27-2007 17:07:45
Anyone know where to pick up Some engine parts for s 5015 (Bearings,Rings,Gaskets).I need to freshen up my neighbors tractor.Thanks
cadet trooper
12-29-2007 04:00:21
 Re: 5015 A/C engine parts in reply to Southern4020, 12-27-2007 17:07:45
Southern, I err'd on my part numbers just put a 7 in front of the AC part# to make it a Simplictiy part # instead of a 70. Sorry.
cadet trooper
12-28-2007 15:12:12
Try SEW.com (Small Engine Parts)click find parts click on Simplicity and compact tractors and it will have a drop down list with Allis Chalmers open that and there will be a list of compact tractors and as of last night the 5015 was on there it will give you a list of sections of the tractor that you can open with parts drawings and part numbers in AC but you can put 70 in front of the numbers and you will have Simplicity part numbers. Print out what you need. Now take it to or call your local AC or Simplicity dealer and see what"s available and pricing. Don"t get discouraged if you check SEW for parts available because it will say not available but you could call them anyway to see. I"ve found they might be cheaper but the freight and handling winds up being more. My e-mail is open if you have any problems. The 5015 is a Toyosha tractor which is out of business but there are a lot of parts available but some aren"t and be prepared to get your checkbook out. I have a 5020 and I liked that 5015.
cadet trooper
12-29-2007 06:52:49
 Re: 5015 A/C engine parts in reply to cadet trooper, 12-28-2007 15:12:12
Geez Southern I must have been totally asleep last night when I typed my first answer. That was supposed to be SEPW.com instead of SEW. Hopefully I'm awake this morning.
