B 1948 Brakes
Bobby Rakestraw
12-26-2007 10:27:04
I have a 1948 B (#80511 i think) and working on replacing the brakes. I was able to get the old bands out by removing only one of the top pins. Do you need to remove both top pins in order to install the new bands.
ed in cny
01-02-2008 18:40:16
 Re: B 1948 Brakes in reply to Bobby Rakestraw, 12-26-2007 10:27:04
I have to do this job this coming spring with my 42 B. Let me know how you made out with this job. I haven't got the time to get at it till march so any help figuring this job out the better.
Ted in NE OH
12-27-2007 19:59:35
Drill a hole where it should be to drive the pin out.
steve(ill)
12-26-2007 15:42:25
yes, remove both pins, blow out and wash out all mouse next and mud, the cleaner, the better. run a heavy bailing wire around the drum and use it to pull the new shoes in. with tire off the ground you can roll the tire and help roll it thru--- its snug.
Bobby Rakestraw
12-27-2007 12:46:14
 Re: B 1948 Brakes in reply to steve(ill), 12-26-2007 15:42:25
How do you get the second pin out, On my B it has no hole to drive it out.
