allis B rear rim
mawc
12-25-2007 15:13:36
I have a allis b with rear wheels the dont use the usual eccentrics it has little square blocks welded to rim everything looks factory i was wondering if allis used different ways to hold the hub to rim
coloken
12-26-2007 11:48:24
 Re: allis B rear rim in reply to mawc, 12-25-2007 15:13:36
Sounds like the B I had. Lugs were welded to rim. Very early B--# 806. No reason to believe it was not factory. Kennyp
Clay in MI
12-25-2007 19:51:32
Massey Pony rims are like that too and bolt right on to the B. I like them better but you are limited to four tread widths. They can be mounted inside or outside the hub or reverse the rims and mount inside or outside.
Mike in Ohio
12-25-2007 18:28:47
Old is right they are for a farmall. If you are not going for a perfect restoration keep them, they won't fall off when you hit a big groundhog hole. The ones with the eccentrics will when they get worn. Merry Christmas, Mike
old
12-25-2007 17:13:31
Sounds like rims made for the Farmall B. Those rims will bolt right on but are made for another brand of tractor.
DS Mi
12-25-2007 16:25:19
I have them on my c they are a newer wheel.I don't like them because on a c you don't have any adjustment.You might be ok on a b,but I'd check it out. DS
