live hydraulics
Richard IN MO
12-23-2007 17:57:11
Thinking about an auxillary pump to operate a loader to the D17. Any ideas on size, type, or ?Thanks
1chicken
12-24-2007 16:06:59
 Re: live hydraulics in reply to Richard IN MO, 12-23-2007 17:57:11
i think the hyd pump on a 431 542 and 5542 cockshutt combine is simalar to the factory pump sold for a 417 allis loader i know because we have wrecked a couple
JMS/.MN
12-23-2007 18:32:48
Front mount pump to provide independent hydraulics for a loader or other was a factory option. Not hard to duplicate if you can't find the original. mounts in front of the steering casting, driveshaft goes through the existing crank hole, coupler bolts to the front pulley.
Richard IN MO
12-23-2007 18:53:01
 Re: live hydraulics in reply to JMS/.MN, 12-23-2007 18:32:48
Do you know specs on original? Gpm?
old
12-23-2007 21:09:20
 Re: live hydraulics in reply to Richard IN MO, 12-23-2007 18:53:01
Most front pumps for loaders where around 8-10 GPM. You don't want much more then that because the lift gets way to fast and can cause you to flip a tractor on its side fast. Found that out by almost doing so. GPM does not mean less lift just slower which believe me is nice at times and can/will save your life
JMS/.MN
12-24-2007 17:23:42
 Re: live hydraulics in reply to old, 12-23-2007 21:09:20
If memory serves me correctly, the WD/WD45 pump put out about 7 gpm at the high pressure, D17 was about the same, maybe a bit more. Remember talking to a dealer many years ago who went to the "unveiling" of the D Series back in the day, and they literally boo"ed the factory reps when they announced the hydraulics. Dealers wanted an improvement.
JMS/.MN
12-23-2007 19:12:27
I would go to a parts book for the number- and from there the dealer should be able to tell you specs. I believe they are Cessna pumps- may or may not be the same as on many Gleaner combines- F, F2, K, etc. Maybe the same as the PS pump on the Series III D17?
