B-10 Variable speed belt size
scottnga
12-22-2007 18:52:08
Does anyone know the size of the variable speed belt on a b10. looks like it is wider than a B 5/8 belt. Size, part number or place to purchase one would be helpfull.
Thanks in advance,
Ida Red
12-24-2007 03:53:18
 Re: B-10 Variable speed belt size in reply to scottnga, 12-22-2007 18:52:08
Anyone have trans axles for a Big 10 Allis.Red
scottnga
12-23-2007 08:24:03
Thanks for everyones help I figured out the cross referencing and got the manual. Only one thing I couldn't find how you got the specs for the part number of the belt. I actually had Found that page yesterday by mistake but cannot reach it now. Atleast I got a manaul now.
Thanks
Scott
leroy in ne
12-23-2007 09:05:54
 Re: B-10 Variable speed belt size in reply to scottnga, 12-23-2007 08:24:03
belt ref link is on parts and manuals page go from there leroy
Jacob in NY
12-23-2007 07:07:49
IF it is the same as the one on a B-210 or a 312, try Simplicity p/n 164080, 54" x 1" wide x 0.5" deep. NAPA can also get them but they"re more expensive than Simplicity ($67 vs $55).
Adjustment of the thing is very important; look on the aforementioned website for the procedure. Clutch pulley belt stop is what keeps the belt from moving when clutch is in; if worn, it will allow the belt to keep slipping along and provide much frustration as you won"t be able to shift well.
good luck, I have had enough with these !$#@%!&^ things and am now looking for a real tractor. Doesn"t help that the rest of the thing is pretty well worn out, and the engine just had something bad happen (rod or rod cap blown; no holes though.)
leroy in ne
12-22-2007 19:16:08
www dot simpletractors dot com parts pages, belt dimensions and much other info on allis and simplicty tractors
scottnga
12-22-2007 19:51:27
 Re: B-10 Variable speed belt size in reply to leroy in ne, 12-22-2007 19:16:08
I have been looking there for a couple hours. I don't know I am sure it is me but I cannot find the item. If I had the part number I could cross it over to a simplicity part I noticed. Cannot find the information on the site just basic information on belts.
leroy in ne
12-23-2007 07:43:24
 Re: B-10 Variable speed belt size in reply to scottnga, 12-22-2007 19:51:27
did a little looking. hint, x-ref tables to simplicity #, ac 2025069=simplicity 990395 ac 2025070=simplicity 990396 use at parts and manuals, i came up with belt # 164080, belt specs show this as an HI belt 1inch top width by half inch depth 53.1 inch outside measurement. double check me on this as i was in a hurry hope this helps. if i remember right the mfg # and serial #is on decal on rear of tractor below seat leroy
