backwards tractor
Richard IN MO
12-21-2007 18:12:52
I was reading about the reversed tractors and got me to wondering if the D 17 would reverse as easily
JMS/.MN
12-22-2007 07:42:55
 Re: backwards tractor in reply to Richard IN MO, 12-21-2007 18:12:52
Yes. Bit more involved than the WD, since you need to get inside the differential, which means removing the rear casting with the lift arms. Then pull out both axles enough to clear the gears, unbolt, flip, rebolt.
old
12-21-2007 19:34:55
I don't know about the D-17 but I know a WD or WD45 could be done easy just by flipping the ring gear from one side to the other
