Question on D-17 water gauge?
loveshisallis
12-20-2007 14:19:47
Hello!
I just put another thermostat in my gas block and checking it with a bulb in the radiator, it shows 170 so , so far, I am happy. THEN, I notice that the water gauge on the dash shows , zero(all the way to the left. So, is there anyway to fix the original temnperature gauge on her, or do I have to bite the bullet and buy her a new one?
Thanks for all your good help and happy holidays!
Kentb of SWMO
12-21-2007 06:06:53
 Re: Question on D-17 water gauge? in reply to loveshisallis, 12-20-2007 14:19:47
I saw a story on a guy who rebuilt gauge like this I had aways wondered WHAT the working fuild in these tube type gauges were. The story said it was ether.
Kent
loveshisallis
12-21-2007 08:40:14
 Re: Question on D-17 water gauge? in reply to Kentb of SWMO, 12-21-2007 06:06:53
Hello;
You wouldn"t know the name of the article where I could learn how to rebuild this gauge would you?
Thanks and Merry Christmas!!!
Kentb of SWMO
12-22-2007 06:53:44
 Re: Question on D-17 water gauge? in reply to loveshisallis, 12-21-2007 08:40:14
I am not sure but I think it was a story about reworking gauges is a Mopar Muscle some years ago. The artisle did not speak of the amount of ether in a gauge. I assume you checked the tubing for no breaks, made a good solder at the bulb end, used a hypo. needle to injsct some ether in the line/bulb assy., and then made the solder joint at the gauge end. The article was not that expansive.
Kent
DiyDave
12-20-2007 14:56:12
If it shows zero, and never moves, its shot. Bite the bullit, pay the $40-60 bucks, and replace it. It'll give you a chance to clean out the bird nests that accumulate under the gas tank! Seriously, though, be careful when removing the side panels, those little 1/4" bolts snap real easy. Also soak the sending unit end of the gauge with kroil for a couple days, you don't want to snap off that thin brass fitting, its a nasty job to remove if that happens. Good luck.
