D15 series 2 Rear wheels
Erich
12-20-2007 06:54:29
I am trying to locate a set of rear wheels for our tractor. Any ideas on where i might be able to find a set?
dej(jed)
12-21-2007 09:30:23
 Re: D15 series 2 Rear wheels in reply to Erich, 12-20-2007 06:54:29
I have used 28", 26" & 24" rims. Quite a few combines use the same bolt pattern. Right now I have a set of 13.6 x 26" tires and rims on my D 15. If you are picky that is another story. Combines offer some hardly used tires and wheel though.
old
12-20-2007 08:14:07
You looking or the rims or the centers. Rim can be got new on this site maybe and or value bilt. Hold on because new there around $300 each. Now if you need centers also you will probably need to find a slavage yard or some one that has them. I have one that would probably fit it came off a D-17
JMS/.MN
12-21-2007 09:26:44
 Re: D15 series 2 Rear wheels in reply to old, 12-20-2007 08:14:07
May bolt on but it would be the wrong size. D17 used a wide 28 inch rim, D15 is likely the same as the D14- had a narrower 26 inch rim.
