WD 45 misfire
SP Indiana
12-19-2007 03:19:16
first off i wuold like to thank all of you for the info that i have rec over the past years, this is the first time i have written in. i have a wd 45 that from time to time #1 spark plug goes cold ,i rest valves, rebuilt carb. new intake and ex gaskets studs, tune up coil, 3 differt spark plugs, some time in its life the head was changed, ? i was told it has a tall head? sparh plug wires are solid wire, ican take the spark wire off and let jump an arc and will be ok for a short time. i have longer than std bosch plugs in it now, i did have factory plugs made it worst. HELP
mlpankey
12-19-2007 18:25:03
 Re: WD 45 misfire in reply to SP Indiana, 12-19-2007 03:19:16
is the plug wet when it starts missing . wet thin but blk in color is oil. you could trie opening the plug gap make it have to jump seeif it gets worse or better,
Texas Denny
12-19-2007 07:16:00
89 is a bit low but should still be usable. I once had a WD with 4 1/8" cylinders. I rebuilt the engine, put in new spark plugs, ignition wires, points, condenser, rotor and d cap. I checked compression right after rebuild and had 130 +/- 2 pounds. It started fine but seemed to miss. I couldn't find a specific plug that was misfiring - seemed to be random. The misfire wasn't always the same cylinder. I did a lot of checking of things. I even pulled the intake manifold and resurfaced it. Finally, in frustration, I removed the new plugs and put in the old plugs. It then started and ran perfectly. The new plugs were Champion. The old plugs were AC.
Your description seems like you have left nothing to be the problem - you've fixed everything. I don't know why one plug would work better in an AC tractor than another. But I have found they all do not work the same. I wouldn't use any Japanese plugs. I wouldn't use any of those ring of fire or multiple electrode plugs. I would simply stick to the plugs that have been proven. I think AC 45 is the best. I don't know the Autolite number, but those work for me as well.
SP Indiana
12-19-2007 06:19:06
i have ran a compression chech 89 lbs +/- 3 per cyl check was done cold
Mark from Ohio
12-19-2007 03:56:19
Sounds like you have an oil burner.Run a compression test on all cylinders and you will probably find that #1 cyl. is drastically lower than the rest.Don"t worry about the amount of compression you have and look more at how even it is.
