WD45 pulling a 10' transport disc??
Tom Yaz
08-07-1998 12:03:39
Hello All!
Is it possible for this tractor to do it with a disk w/conventional drawbar hitch?
(My understanding is that the WD45 has 37 drawbar HP.)
If so, what is the highest gear one can go??
Would like to also drag a single-set of 10ft harrow
behind it. Reason asking is I saw a nice looking JD
disk that would replace my beat up 7ft IH disk.
The old timers around here say no way-any input??
Thanks
Ted Buisker
08-08-1998 06:53:07
 Re: WD45 pulling a 10' transport disc?? in reply to Tom Yaz, 08-07-1998 12:03:39
: Hello All!
: Is it possible for this tractor to do it with : a disk w/conventional drawbar hitch?
: (My understanding is that the WD45 has 37 drawbar HP.)
: If so, what is the highest gear one can go??
: Would like to also drag a single-set of 10ft harrow
: behind it. Reason asking is I saw a nice looking JD
: disk that would replace my beat up 7ft IH disk.
: The old timers around here say no way-any input??
: Thanks
Your 45 should play with that disc! Provided it is weighted for field work, with fluid filled tires. I pull a 12ft Krause with 18" blades and two 7' sections of spike tooth harrow with my 45D in third gear, no problem. I do use duals in plowed ground. My question is , Why would you want to degrade your Allis by hooking it to anything painted green!!! Have a g'day. TED
Dave Kolbenschlag
08-10-1998 17:17:37
 Re: Re: WD45 pulling a 10' transport disc?? in reply to Ted Buisker, 08-08-1998 06:53:07
: : Hello All!
: : Is it possible for this tractor to do it with : : a disk w/conventional drawbar hitch?
: : (My understanding is that the WD45 has 37 drawbar HP.)
: : If so, what is the highest gear one can go??
: : Would like to also drag a single-set of 10ft harrow
: : behind it. Reason asking is I saw a nice looking JD
: : disk that would replace my beat up 7ft IH disk.
: : The old timers around here say no way-any input??
: : Thanks
: Your 45 should play with that disc! Provided it is weighted for field work, with fluid filled tires. I pull a 12ft Krause with 18" blades and two 7' sections of spike tooth harrow with my 45D in third gear, no problem. I do use duals in plowed ground. My question is , Why would you want to degrade your Allis by hooking it to anything painted green!!! Have a g'day. TED
Your Wd should pull that okay in 3rd gear unless the soil is really heavy and wet. That is really an easy load for the tractor.
Dave
Denny
08-07-1998 12:18:58
Tom, we puled a 10 foot Allis drag type tandom disk with WC's in
2nd gear. When we put 4 1/8 cylinders in the WC's, we could
easily go in 3rd. We had a WD with 4 1/8 cylinders which
loafed in 3rd gear. A WD-45 has a little more power than the WD with 4 1/8 so I reckon it should be no problem. Don't see
a problem with the 10 foot harrow either as it should pull
easier than the tandom disk.
Regards,
