7080 stopped pulling
bonoac
12-14-2007 21:58:48
7080 stopped and will not pull engine pulls down on clutch release but tractor does not move. all gears and range same you can hold high power dir button down and no pull on engine but still will not pull tractor.any info thanks
856 puller
12-15-2007 06:04:22
 Re: 7080 stopped pulling in reply to bonoac, 12-14-2007 21:58:48
Do you have hydraulics will it steer will the engine want to stall if you let the clutch out in gear or out of gear. if thr torquelimiter disc fails it wont drive or have hyd. psi i have seen that the most look thru the hole in in the bottom of the trans housing by the enging and see if there is parts laying in there like broken springs sometimes you can see the bad plate
bonoac
12-16-2007 15:07:44
 Re: 7080 stopped pulling in reply to 856 puller, 12-15-2007 06:04:22
yes the hyd still works stalls in all gears you can pull it with another tractor easily so i thought it must be in the power director but was looking for some input on the prob thanks.
856 puller
12-17-2007 05:37:08
 Re: 7080 stopped pulling in reply to bonoac, 12-16-2007 15:07:44
if it stals when you let the clutch out in netural it could be the hollow shafts under the power director locked up.
