Tire changing help please...
loveshisallis
12-13-2007 16:33:20
Hello;
I am thinking of getting new tires to replace the 5.50 x 16 on my allis. Is there a way a guy can do this himslef? Do I need to buy something special to do it, or it is best to just take it in and have them change them?
Clay in MI
12-14-2007 04:46:22
 Re: Tire changing help please... in reply to loveshisallis, 12-13-2007 16:33:20
I change mine the same way Dick suggested. But afterwards I usually wonder why I didn't just take it to the tire shop like a normal person! Try getting the old tire off. If you succeed at that putting the new one on is the easy part.
BobHnwOh
12-14-2007 03:56:08
I think you better have someone else do it!!
Texas Denny
12-13-2007 19:34:53
I break the bead by placing a high lift jack next to the rim over the tire. Place this underneath a draw bar of a good sized tractor. Operate the jack and the bead is pushed off the tire. Flip it over and do the other side. I've used the same method on rear tires. Be careful on the rears - they can be extremely heavy.
Dick L
12-13-2007 19:18:47
That size I change with a pair of large screw drivers. Break the bead down on both sides by driving up on the tire or a bottle jack under something heavy like a large tractor drawbar or big trailer frame. I take my foot and hold the tire bead down in the center of the rim on one side and start prying the bead over the rim on the opposit side. Then just walk it around and off. After the bead is broke down it only takes minutes with just two big screw drivers. If the tire is rusted fast getting the bead broke down can be a job in its self.
Plowjock5
12-13-2007 18:33:01
If you dont have the proper tools have someone do it for you.
DS Mi
12-13-2007 18:09:29
If you do it yourself you can clean rust off inside of rim. Treat the rust with converter. and then put a layer of duct tape around inside of rim for protection. DS
old
12-13-2007 17:02:58
Yes a person can do it them self if they have all the right tools. You need a tire hammer and a pair of tire spoons. If you don't have them then you will end up spending around $100 for the tools and if you don't know how to use them you can destory a rim. Best thing is to bit the bullet and have it done
