190xt thinking of getting
Floyd352
12-13-2007 12:54:10
A neighbor has one with a BAD clutch. and a turbo that is leaking oil badly. Tires are good but tractor hasn't been run in 2 years [its outside]. I was wondering about parts and availablity. Price is 2000 which I think might not be too bad. Also thought take the turbo off as I had a 190 that didn't have one. Yes this is the neighbor who was using it [before I got to] and the rebuilders put 2 crank end capson backwards resulting in a unrepairable hole in the block. I still have that tractor on the hope that I'll find a motor
180doug
12-14-2007 04:27:17
 Re: 190xt thinking of getting in reply to Floyd352, 12-13-2007 12:54:10
Price dont seem bad , you could keep the turbo off like you were thinking ,itll have plenty of power; Im interested in both if you wanna sell !!!!!
old
12-13-2007 15:58:27
Depends on the series it is. If a series 1 or 2 thats way to much. In my area a good running XT190 will only bring in around $2500 with good tires and all gears working as they should unless it has a cab then add $300-500 more. The way that one sits maybe $800-1000, because your looking at another $1000 plus to get it fixed right and thats if you do all the work your self
Floyd352
12-13-2007 13:16:17
Oh I thought $800 for a turbo was high and I don't need the power as all I do is hay with this size tractor.
Joe(TX)
12-14-2007 04:46:20
 Re: 190xt thinking of getting in reply to Floyd352, 12-13-2007 13:16:17
$800 for a turbo is high. I have had several rebult and the most I ever spent was $500, and that was replacing the housing.
Jack a
12-13-2007 14:20:59
$1,500 would sound better. I paid $2,400 for a straight 190 that is tight (3,400 hrs) and runs very good. Maybe I got lucky.
