wdallischalmers
gene watkins
12-11-2007 17:42:23
i wrote last week about stuck moter,still stuck. i found ser# wd98448 makes it 1951. motor #wd306773pa, whats pa stand for ?.also need manifold for same motor. thanks
Texas Denny
12-13-2007 16:23:05
 Re: wdallischalmers in reply to gene watkins, 12-11-2007 17:42:23
There is a WD manifold on EBay auction #350005786620 for a WD manifold. It looks like there is plenty of steel left on this one though I didn't study it long and hard and no one except the owner knows if it is flat on the mount to the head.
JMS/.MN
12-13-2007 08:08:16
If it"s a "PA" engine, make sure you get the right manifold for it. Low compression manifold is different.
stu (ON)
12-12-2007 04:05:45
The PA designation means that the engine is designed to burn gasoline of 70 octane or higher, rather than lower octane gasoline, distillate or tractor kerosene. One source of a new manifold is this site. Go to the top of this page and click on "Parts" and then follow the menus through "Allis Chalmers" to "WD" to "Exhaust System".
old
12-11-2007 20:30:50
Blow out the cylinders and then fill with tranny fluid and walk away for a month
