D-17 front tires sizes?
loveshiallis
12-10-2007 17:14:20
Hello;
what is the difference in the front end tires sizes for a D-17 ? I know that I have 5.50 x 16 now, but am thinking of going bigger, say to 7.50. Let me know what you think about the pros and cons of what tire size is good for what.
Skyhighballoon(MO)
12-10-2007 19:43:07
 Re: D-17 front tires sizes? in reply to loveshiallis, 12-10-2007 17:14:20
My manuals list 5.50X16, 6.00X16 and 7.50X16 as standard tire sizes for a Series IV. I have 6.00X16 on mine now but would recommend 6.50X16 as that is the largest size you can put on without a wider rim. If I had been paying closer attention when I bought new tires I'd have the 6.50X16's. 7.50X16 will need an inch wider front rim and I'd only recommend that big a tire if you have a late Series IV with the heavier 6 bolt hubs instead of the 5 bolt ones. And that's if you have a wide front. If it's a narrow front I think 6.50 is as big as you can go. Mike
old
12-10-2007 18:07:01
You can probably go up to that size but if you don't have power steering it will make it steer harder. Good thing is with the wider tires in soft stuff you will not sink as bad.
