HELP!! AC D12 Timing Mark(s)
Donald Gay
12-09-2007 14:26:21
I have a D12eries III tractor. There is two marks o the flyweel stamped TDC, which one do I use? I think I am correct on this but isn"t the front Cylinder the #1 cyl?
George R. (MN)
12-09-2007 17:55:23
 Re: HELP!! AC D12 Timing Mark(s) in reply to Donald Gay, 12-09-2007 14:26:21
Don,
The timing marks on the flywheel should be marked "F" or Fire and TDC (top dead center). TDC is used for static timing. When engine is running and using a timing light the "F" or fire mark is used. As for #1 cylinder you are correct. The firing order is 1,2,4,3. Good luck on your project! George
