Hyd on 190
strommen
12-08-2007 06:40:48
I have a 190 that the hyd acts just like it is running out of oil but the level says full. any ideas
Jr64
12-10-2007 04:23:14
 Re: Hyd on 190 in reply to strommen, 12-08-2007 06:40:48
Check your suction line to make sure the lines don't have a hole rubbed through them. Check the rubber hose splices to make sure the rubber hasn't deteriorated and is leaking air. There's an outside chance that the splines on your pump are going out, but usually the pump stops and your done.
Jerry Coulter
12-08-2007 08:47:43
Changing the spin-on filter under the operator's platform did the trick for me.
strommen
12-08-2007 11:38:49
 Re: Hyd on 190 in reply to Jerry Coulter, 12-08-2007 08:47:43
did that -didn't help
