AC 190 tractor
Dan Matthias
12-06-2007 17:46:28
I need help with starting a diesel tractor that my wifes aunt has, what do you do to get this beast going in zero weather ? Thanks DAN
180doug
12-08-2007 04:44:19
 Re: AC 190 tractor in reply to Dan Matthias, 12-06-2007 17:46:28
If it has a block heater or a heater in the water cooling system just plug it in a few hours ,or put one of these on ,a good battery a little either well get it going ; Want to sell it?Im looking for a 190 !
Richard Ritter
01-12-2008 15:02:13
 Re: AC 190 tractor in reply to 180doug, 12-08-2007 04:44:19
I have a 190 that spun a main bearing and has not been running for 10 years. Would sell it for any reasonable offer. Location--southern Indiana.
Jack a
12-07-2007 04:21:15
Put in a tank heater if it hasn't got one. Makes sure it has winter blend fuel. If you already tried strating it with #2 summer fuel then you might as well replace the fuel filter and clean the sediment bowls. Fill the filter and sediment bowls with #1 fuel. Either drain the fuel tank if full of #2 fuel or if it is less than half full add #1 fuel to it until about a 50% blend. The tank hold 48 gallons to give you an idea. Put a battery charger on it and give it a little snort of ether if needed. Don't use the manifold heater if your going to use ether. Once you have it going you shouldn't need ether if you just plug it in. Keep a couple of fuel filters and sediment bowl gaskets and screen on hand just in case.
Dan Matthias
12-07-2007 13:40:03
 Re: AC 190 tractor in reply to Jack a, 12-07-2007 04:21:15
thanks Dan
Randy Turner
12-06-2007 18:30:47
You will probably need some electricity. Either for a battery charger/starter and/or a block heater if it has one. New fuel and clean fuel filters wouldn't hurt. As a last resort you could try a little ether. A little cranking alternating with small waiting periods should get it to fire if the motor is in good shape.
