Torque on rod nuts?
TroyR
12-05-2007 14:10:35
1939 Allis B I was wondering if someone could tell me what to torque my connecting rod nuts to.Next time I order something I'll get a manual.Any suggestions on what manual to get?
JMS/.MN
12-05-2007 17:16:01
 Re: Torque on rod nuts? in reply to TroyR, 12-05-2007 14:10:35
On any tractor, the OPERATOR manual gives you details on ID of the controls, basic lube recs, where to find fill and drain plugs, basic maintenance, how to drive the tractor. Service/shop manual tells you how to take things apart, measure wear, and fix things. Parts manual gives you part numbers and exploded views as to how everything fits together. Operator manual is the most basic one to buy- to learn how to operate your tractor.. When you get into fixing it- you need the service manual- I&T or original AC manual. Torque specs are in the service manual. That is the second book you should buy.
Dick L
12-05-2007 16:14:23
I have always torqued to 35 pounds and then beyond to the where I could get the cotter key in. It will end up just under or just over 40 pounds. All close enough for you not to have a problem.
old
12-05-2007 14:40:07
My I-T manaul says 40ft/lbs
