G camshaft question for the N62
Eddy62
12-02-2007 19:47:36
What does the factory recommend for tightening the camshaft nut that holds the timing gear? And I also can't find the torque setting for the front crankshaft nut?
Thanks for any help you can give
ED
Jeff Z.
12-03-2007 06:21:41
 Re: G camshaft question for the N62 in reply to Eddy62, 12-02-2007 19:47:36
Since the gear is pressed on the cam and the thrust plate controls end play I would just make sure it is on tight. You can use some loctite if you want.
