Serial number on 45?
Hossman
12-02-2007 12:59:17
Fella,s I am lookin at an ol 45 a local guy is wantin to sell and ive located the serial # on the left side of the engine for the motor but am havin a time tryin to locate the actual tractor serial#. I looked under the brake cover housing on the left side were ive always found em in the past but theres no# here.The guy actually took a wire wheel to the housing under the brake cover and shined her down to the bare metal, no number.I own 2 of these 45,s an 55 and 56 and there both located in this locale.As I recall there was another place to look but I cant remember. Im sure this is an original 45 and no cobbled up mess,the engine # says also its a 45. Any help her on where else to look would be great I know someone has to have a 45 with the serial # located in this differant spot. Thank alot, Hossman
stu (ON)
12-04-2007 04:09:39
 Re: Serial number on 45? in reply to Hossman, 12-02-2007 12:59:17
My '51 WD has the tractor serial number stamped on the top edge of the hydraulic pump casting just inboard of the hydraulic hold valve. I would not have seen it without removing the paint.
Can't speak for other years, but in the WD45 Service Manual, Supplement No. 22, there is a drawing that shows a number stamped there also.
Jeff Z.
12-02-2007 20:20:00
Send me an email and I'll send you a picture with the location.
Jeff Z.
12-02-2007 20:17:32
Check the rear face of the transmission.
