WD 45 Wide Front
Mike Dunica
11-29-2007 16:31:09
Hi,I was wondering if a Allis wide front off a WD or WD45 fit on any other narrow front WD or WD45? I can get one but didnot know if it would bolt up to my narrow front. Thanks
JMS/.MN
11-30-2007 13:55:32
 Re: WD 45 Wide Front in reply to Mike Dunica, 11-29-2007 16:31:09
Frame widths are the same on WC, WD, WD45, so the fronts interchange. Later wide fronts were bolted to the cast steering housing, and you could interchange a single front wheel, tricycle front, or wide front. Some called the tricycle attachment a "corn picker" front- you pulled off the wide front in the fall, bolted on the tricycle front, and mounted the corn picker to the tractor. I found that steering casting this summer, along with a single front yoke- still looking for the tire, axle, bearing assembly.
Texas Denny
11-29-2007 19:25:19
Same is true of the WC but some of the cultivator mountings are different.
old
11-29-2007 16:48:47
If complete it will fit just fine. All front ends wide or trike will switch from one to the other if you have all the parts with it
