D17 Diesel - add inline coolant heater?
Packer Backer
11-29-2007 15:53:20
I would like to add an inline heater to my D17D. Which loop is the best to install this into? I have an early series diesel... Thanks
Scott
DiyDave
11-30-2007 16:59:23
 Re: D17 Diesel - add inline coolant heater? in reply to Packer Backer, 11-29-2007 15:53:20
My setup never heated up the radiator! I may have mis-stated which line I hooked up to, as it has been a few years since I made the hookup. Best advice is to follow the instructions that come with the heater unit!
Kentb of SWMO
11-30-2007 06:16:24
If you do as DIYDAve does you tun thr risk of the heated water circulating through the radiator. The heated water may open the thermostat. On Dad's 190 we ran the inlet to the heater from the block drain and the outlet of the heater went to a hole we tapped into the lower radiator hole connection on the water pump.
Kent
DiyDave
11-29-2007 17:05:04
If it's the same motor as is used in a D-19, what I did was to put a coffee pot heater on the right side of the motor, from the block drain port, and tee into the thermostat bypass line at the top of the motor.
