wd 45 d17 crank interchangabilty
drajger
11-27-2007 16:05:53
Is there a kit or anyway to convert a d17 crank over to a wd45. I have a wd45 with a bad crank. However I have a new d17 crank laying around. Has anyone ever heard of this or know if its possible.
Thanks
Kip-Utah
11-28-2007 06:18:50
 Re: wd 45 d17 crank interchangabilty in reply to drajger, 11-27-2007 16:05:53
Cal nailed it. The 17 has larger diameter main bearings that I suppose could be turned down,I vote for getting a new 45 crank. Kip
mlpankey
11-27-2007 22:53:41
i think the mains are in different locations . could be wrong . cant remember as well . know theres a question of intercange ability
CAL (KS)
11-27-2007 19:13:50
if i remember correctly d17 journals are larger, but it could be turned down. also i think the crank gear is different from early 17's (same as 45) and later ones. so i depends on which one you have
drajger
11-28-2007 15:59:45
 Re: wd 45 d17 crank interchangabilty in reply to CAL (KS), 11-27-2007 19:13:50
Thanks guys for the responses. I wasn't sure but thought it was worth asking. I may have a coworker that can help me out with a crank.
Thanks again.
