Aggravating Allis C oil leak
Jim in NC
11-25-2007 14:21:50
I have a leak where the oil filter mounting assembly bolts to the block. I have made gaskets from paper and cork gasket material. The leak will stop for a while, then start again, and I will tighten. This will repeat itself until I eventually tighten several times and cut the gaskets. What am I doing wrong? Thanks for your help.
patsublett
11-26-2007 10:36:39
 Re: Aggravating Allis C oil leak in reply to Jim in NC, 11-25-2007 14:21:50
I had a Ferguson 40 with a Continental engine that had a blank sheet metal plate where the power steering pump attached; It leaked from the time it was new. I tried every kind of gasket. Finally, I cleaned both surfaces with laqure thinner, let it dry and used blue RTV cement. I learned that it is extremly important to clean both surfaces before applying the RTV. If the surfaces have been exposed to oil, it is a good idea to warm it with a propane torch, wipe it several times and clean with some kind of non residue solvent before applying the RTV.
Dick L
11-25-2007 14:29:14
If you have paint under the gasket on the block it will not seal. Most blocks are quite uneven and it takes a thick cork gasket. Run a large flat file over the filter housing where it mounts to the block. Sometimes they are not flat because of over tightening.
Jim in NC
11-25-2007 19:39:35
 Re: Aggravating Allis C oil leak in reply to Dick L, 11-25-2007 14:29:14
Thanks Dick, I will try the things you suggested. The C had been painted a few years ago so I will check the block for paint. When I put the gaskets on, I doubled the paper and cork gaskets. The cork was much thicker that the paper. I will check for straightness as well.
