Shift Lever Pivot Pin
J. Wondergem
11-24-2007 14:28:07
Does anyone know what the shift lever pivot pin is made from? Mine seems to be made from something nonmagnetic. I can't remove the broken piece with a magnet. I figured it would be cold roll.
JMS/.MN
11-24-2007 16:52:38
 Re: Shift Lever Pivot Pin in reply to J. Wondergem, 11-24-2007 14:28:07
Steel. Probably "mushroomed" on the edge that was in contact with the shifter. You can pull the shifter out, then hit it with a little punch. The slot on the shifter goes from top to bottom, so you should be able to pull the shifter out.
J. Wondergem
11-25-2007 15:53:44
 Re: Shift Lever Pivot Pin in reply to JMS/.MN, 11-24-2007 16:52:38
OK, thanks. I'll try that.
