WD front hubs
larrystg2
11-24-2007 09:52:56
Will the front hubs off a C fit a WD?
JMS/.MN
11-24-2007 16:55:56
 Re: WD front hubs in reply to larrystg2, 11-24-2007 09:52:56
No. Hubs that fit a WD: WC, WD, WD45, WF, RC. Maybe even a UC- don"t know. Likely some D series. too. But not a B, C, CA. Different class size of tractors.
larrystg2
11-24-2007 15:27:33
Thanks to all the replies. I was wanting to use the aluminum drag lite wheels with a 5 bolt pattern.
old
11-24-2007 11:33:29
If you need a hub I have a WD parts tractor out back. E-mail is open
Jeff Z.
11-24-2007 10:50:03
This might help you with hubs.
These should fit the WD:
D14,WD45,
D17 Series 3 with serial numbers below 42001
D15 with serial numbers below 9001
D12 with serial nubers 3001-9000
D10 with serial numbers above 3501
Jeff Z.
11-24-2007 10:23:25
No.
