'59 D-17 Diesel Front Rims
Kevin (FL)
11-21-2007 09:55:43
Anyone know the factory original rim size (fronts) for this tractor? Ours has a set of welded rims and "balloon type" loader tires mounted and I'd like to get the original tire and rim sizes on it. Rears are factory original size, so no change needed there.
Thanks for the assist and happy Thanksgiving to all.
old
11-21-2007 11:17:47
 Re: '59 D-17 Diesel Front Rims in reply to Kevin (FL), 11-21-2007 09:55:43
Tire size should be a 6.00X16 but the 6.50 and 7.00 and 7.50 will all work just fine and look ok. Rim for the 6.00 is a 4 or 4.5 and the lager ones a 5 or 5.5 X16. A lot depends on what your going to do as to which tire/rim will work best. If you use a loader or other front mount stuff the wide tires work better
Jeff Z.
11-21-2007 10:41:25
Sorry I gave you the tire size.
Rims were 4.0x16.
There is also a heavy duty one if you have a large snow plow on your forks or loader.
4.5x16
Kevin (FL)
11-21-2007 17:29:13
 Re: '59 D-17 Diesel Front Rims in reply to Jeff Z., 11-21-2007 10:41:25
Jeff,
Thanks for the quick reply--I forgot to ask about the number of lugs--ours has 5. Would that be the original hubs? I've seen some D17's with 6 lugs.
Jeff Z.
11-21-2007 10:16:41
As far as I know they were the same on the gas d17.
Jeff Z.
11-21-2007 10:13:00
I believe they were 6.00-16.
Happy Thanksgiving
