7050 oil pressure
jack hi
11-19-2007 17:11:42
i changed oil,and filter when hot no oil pressure. i checked with manual gauge at idle, and about 7# high rpm. would cam bearings be bad along with crank? i have no histry on this,i bought with bad trubo.
Phil Munson NY
11-19-2007 19:29:58
 Re: 7050 oil pressure in reply to jack hi, 11-19-2007 17:11:42
If you only have 7 pounds oil pressure that is probably why the turbo blew. Get "the book" or some help and turn up the relief valve. My guess is that somewhere around 35 to 50 pounds oil pressure is needed. best, Yeoman
jack hi
11-21-2007 15:37:23
 Re: 7050 oil pressure in reply to Phil Munson NY, 11-19-2007 19:29:58
thanks for input. i never thought about the 2nd item ,was really the first in line.
