Buda/Allis Engine
Dave Sherburne
11-13-2007 15:32:06
I'm working on a 6DA273 Diesel engine in a Cockshutt tractor, and I need a head gasket. Since Allis bought out the Buda engine co, I thought
I would ask here. This engine has 3 3/4" bore, and I wonder if any Allis engine has this bore.
Dan Arnold
11-16-2007 19:27:16
 Re: Buda/Allis Engine in reply to Dave Sherburne NY, 11-13-2007 15:32:06
Allis Chalmers used the 273 engine in the TL-12 front end loader the head gasket should be the same as the 262 and 230 diesel engines
Dave Sherburne NY
11-17-2007 13:57:08
 Re: Buda/Allis Engine in reply to Dan Arnold, 11-16-2007 19:27:16
Its different, the 273 has a 3 3/4" inch bore, the 230 has 3 9/16" BUT if they used a 273 maybe they have the right gasket. Thanks
Dan Arnold
11-18-2007 18:44:40
 Re: Buda/Allis Engine in reply to Dave Sherburne NY, 11-17-2007 13:57:08
We have a 230 diesel and a 262 diesel bores are different between them also and calls for the same gasket on each the bore on the cylinder head gasket is 3 and 15/16'' so putting it in a 3 and 3/4'' bore should not be an issue also knowing parts are getting harder to find there may only be one gasket made for all these engines , cylinder heads will also interchange between all three engines
Tradititonal Farmer
11-15-2007 08:11:08
No AC ever used the 273
Dave Sherburne NY
11-16-2007 05:40:50
 Re: Buda/Allis Engine in reply to Tradititonal Farmer, 11-15-2007 08:11:08
Thanks for an answer to the question I asked.
Tramway Guy
11-14-2007 08:20:42
Post this on the Oliver/Cockshutt Board. I know that a Mr. Phil Heisey has a lot of Cockshutt parts, and if he can't get it, nobody can.
El Toro
11-14-2007 04:11:21
Send an email to [email protected] or call them at 318-222-3348. www.agkits.com may have or be able to get parts call them at 1-800-437-3609. Hal
