Alice Chalmers WD45 top speed
David N
11-13-2007 11:47:50
I am looking for the top ground speed of an Alice Chalmers WD45 4500lb tractor for a project. Can anyone help me determine the top speed in low gear at full rpm's? Thanks.
Texas Denny
11-14-2007 06:51:21
 Re: Alice Chalmers WD45 top speed in reply to David N, 11-13-2007 11:47:50
You don't say why the actual speed is important. There are too many variables to be able to predict it. Tire size is the big one but tire inflation makes a difference as well as does tire wear. If you want to know precisely, buy a small GPS unit. They are pretty handy for cars and tractors.
mlpankey
11-13-2007 21:23:27
its all in tire height 15.5 38s second gear 5500 rpms 12 mile an hour easily 1st gear 1500 rpms same tires 3.5 mile an hour .but yes a gps will tell you .
Brad Wright of MO
12-18-2007 14:57:04
 Re: Alice Chalmers WD45 top speed in reply to mlpankey, 11-13-2007 21:23:27
I have never heard of a wd-45 turnin 5500 rpm's.
Bill(Wis)
11-13-2007 20:03:17
Bill-Utah has the best advice. Any decent GPS receiver will be accurate within 1/10th MPH steady state. Just make sure it's set up for statute miles per hour and not nautical mph (knots) or kilometers per hour. Easy to select on most.
Bill_Utah
11-13-2007 17:49:38
Use a GPS to measure your speed, it will be the most acurate you will get.
Bill
JMS/.MN
11-13-2007 13:37:22
Paul's numbers are straight from the book, with standard size tires. Factory option of 13x28 will be slightly faster.
J Plunkett
11-13-2007 13:13:37
Run for 60 seconds measure distance traveled and do the math, distance times 60 divide by 5280 will tell how fast
Paul from MN
11-13-2007 13:12:02
1st - 2.50mph
2nd - 3.75mph
3rd - 5.00mph
4th - 11.25mph
Rev - 3.25mph
Kip-Utah
11-13-2007 12:40:20
Don't know about an "Alice" Chalmers, but an Allis-Chalmers WD-45 will go about 12-14mph if everything is in stock configuration & tune. A D-17 or 175 governor spring would speed things up a little. Kip
Mr. Bob
11-13-2007 12:10:44
Have someone "travel clock" you in an automotive vehicle.
