hydraulic problem 170
bob from ill
11-12-2007 17:37:03
I have a 170 with a 500 loader. I use dextron 2 trans fluid for the hydraulics on all my allis tractors, d17, 190, wd45. Anyway the 170 system is tempermental in the fact that it gets jerky and locks up, when i say locks up i mean it feels like it is at the end of the stroke on the cylinder. If i put the valve to float it will come out of it after a bit. Just wondering if the oil is foaming and getting air in the pump or something. The system is full of fresh fluid.
Skyhighballoon(MO)
11-13-2007 20:43:21
 Re: hydraulic problem 170 in reply to bob from ill, 11-12-2007 17:37:03
Dexron II as in automobile automatic transmission fluid? You should not be using that in your hydraulics for any of your tractors. The only thing I can think of that you can run ATF fluid in would be the power steering on the D17. In all your tractors you should be using universal trans/hydraulic fluid rated for the AGCO/Allis-Chalmers 821XL Power Fluid specification. Drain and flush your tractor and fill with the right fluid first before diagnosing the problem further. Good luck. Mike
