louvers for radiator
squezon
11-11-2007 14:03:06
I have a 39 B that somebody didnt think the tractor needed them. Linkage to open and close thkem is gone also. I would like to find a set so I could cntrol the tempature.
jeffalex2
11-12-2007 02:49:22
 Re: louvers for radiator in reply to squezon, 11-11-2007 14:03:06
I have louvers on my '50 B...they are operated from the front of the tractor with a small crank that sticks out the side of the grill housing. Unless you lube and use them all the time, they seize up and you have to take the hood and grill off to fix...a real pain.
DARDAN
11-11-2007 22:13:58
Actually, their called shutters. They were prone to going to pot and not working. When I use my tractors in cold weather, I just let a trash bag suck fast to the grille after I start the tractor and adjust it to control temp. Warm engines last longer. It isn't preety but it is cheap and works.
DavidKittle
11-11-2007 14:37:16
Hello;
There are some louvers for sale on ebay,now, if you are interested.
Hope this helps
Kentb of SWMO
11-11-2007 14:07:16
These were used when running tractor fuel (distillate) to keep the engines temp. up to keep the engine running. If you are running liquid gold, I mean gasoline, you need not worry about the louvers.
Kent
