rod bearings
heavy hauler
11-09-2007 18:05:29
what the rod bearing torc on a1949 ac 4cyl gas engine
JMS/.MN
11-10-2007 14:37:42
 Re: rod bearings in reply to heavy hauler, 11-09-2007 18:05:29
In 1949 AC was making the WF, WD, B, and C tractors, plus power units using the same engines. WD and WF were 201 cu. inch, B and C used a 125 cu inch. Specs on the 201 are 40lbs on the self-locking nuts, 70 lbs if the castellated nuts are used, along with a cotter pin. On the 125 cu inch engine, torque is 40 lbs.
old
11-09-2007 20:11:06
What model tractor is it. Theres probably 4 or 5 of them and they are all different. In 1949 there would be the WD, WC, B, and the CA and C so we need more info
