W D 45 shifter problem
doorman
11-06-2007 18:37:35
I just bought a WD 45 and it has a problem in the shifter. It was locked in two gears when I went to get it and I had to remove top cover of transmission to get it out of gear. I took the shifter rod out of the tower, and got the shift forks back to neutral and when I reinstalled shift rod it doesn't seem to engage the shift forks. There is some play in the keyway on the shift rod but the ball on the bottom of the rod does not look excessively worn. Any help would be appreciated. Thanks doorman
Doug Erenberger
11-08-2007 15:57:04
 Re: W D 45 shifter problem in reply to doorman, 11-06-2007 18:37:35
Thanks I just posted a question on the same problem ! Doug Erenberger
11-08-2007 15:50:21
12.217.71.4
98246
Help the shifter linkage is stuck ! I'm new to this what do I do !
Texas Denny
11-07-2007 05:13:58
Since there is no reply from someone who has specific knowledge, I'll recount what I remember from earlier posts.
I recall someone who said they couldn't get this installed correctly unless the tractor was in first gear and they placed the shift lever for that gear position. Another said that wasn't necessary but that it was very tricky.
So the most likely scenario is that the lever is in the wrong place. Yes, they do wear out but usually work even when well worn. You might try reinstalling it again or perhaps even a third time.
