info on ca
amo
11-02-2007 18:26:26
I have a chance to get a model CA and equipment from thje original owner, that has not been run in several years, it has been under a shed with a tarp over it. Is this a reliable, model and are parts readily available. I have a 1943 John Deere model B and a 1952 Case model VAS that i have redone. Thanks for the information.
patsublett
11-02-2007 19:03:13
 Re: info on ca in reply to amo, 11-02-2007 18:26:26
It is a very nice tractor. It is similiar to a C but has an additional forward gear, a hydraulic lift with a draft control and a second clutch (hand operated) which allows you to stop the tractor and continue running the PTO. Most parts are readily available. The hand clutch can be a maintenance problem, because water and dirt can easily get into the housing. If it has been covered, that should not be a problem.
Dick L
11-02-2007 18:40:55
The CA is a very nice fun tractor.
Nat
11-03-2007 10:20:17
 Re: info on ca in reply to Dick L, 11-02-2007 18:40:55
I have a B- and a CA. The CA is a lot more tractor than a B. 1. it has more HP. 2. The final drives are tilted back so it isn"t as light in the front. 3. better brakes. 4. one more gear. 5. better seat. 6 better seat. 7. better seat. I may have forgotten to mention the CA has a better seat also later, Nat
Dick L
11-03-2007 11:28:06
 Re: info on ca in reply to Nat, 11-03-2007 10:20:17
Just in case you might have missed it the CA does have a better seat. (:^D<{
jk
11-03-2007 16:01:04
 Re: info on ca in reply to Dick L, 11-03-2007 11:28:06
I LIKE MY C SEAT DANG IT!!
Mark/Ks
11-03-2007 17:53:18
 Re: info on ca in reply to jk, 11-03-2007 16:01:04
I too, like a C seat better,, Soft and cushy, with a back rest.. What more can one ask for???
mark
11-05-2007 12:40:00
 Re: info on ca in reply to Mark/Ks, 11-03-2007 17:53:18
No hemorrhoids!
