XT 190 problems
down and out in
11-01-2007 20:18:57
IGOT A XT 190 THAT DEFINITLY HAS ELECTROLISIT GOING ON IN IT THE BLOCK IS PITTED IN THREE CYLINDERS. THE MECHANIC I GOT WORKING ON IT THINKS HE COULD FIX THE BLOCK WITH JB WELD AND PUT NEW SLEEVES IN IT IS THIS A GOOD FIX HAS ANYONE TRIED IT BEFORE AND DID IT WORK WELL FOR THEM? I HAVE ALSO LOCATED A USED COMPLETE MOTOR BUT SOUNDS LIKE IT MAY HAVE SOME AGE ON IT TOO NO GUARENTEES COME WITH IT I MIGHT BE ABLE TO HEAR IT RUN BUT IT MAY HAVE PROBLEMS TO PRICE IS 1500.00 OWNER DOES NOT KNOW MUCH HISTORY ABOUT MOTOR.
cadet trooper
11-05-2007 15:39:24
 Re: XT 190 problems in reply to down and out in missouri, 11-01-2007 20:18:57
After you fix the problem you should be able to obtain from AC or Agco a coolant conditioner kit that will help with this problem it is definitely not a new problem but seemed to occur with turbocharged tractors due to piston travel speeds or feet per minute causing a static electrolisys that eats away at metal surfaces the conditioner has something to do with removing ion charges in the coolant I'm not schooled in chemistry but as was mentioned the new coolants may have inhibitors.
Jack a
11-02-2007 04:15:37
Best way is to send the block to a machine shop to install sleeves where the o-rings seal. Yes I have used J-B weld and also liquid steel and both seemed to work. That was in the early 90's and I don't know if they are still going cause I haven't worked out of that shop since 1995. After you get it fixed make sure you use antifreeze designed for diesels and change it every couple years. I use Fleetguard.
Plutos
11-04-2007 16:03:42
 Re: XT 190 problems in reply to Jack a, 11-02-2007 04:15:37
Had the same problem in early 90's in XT 190, used liquid metal and is still going. Only on light duties though.
