wd45 engine into a ca
Mike in Ohio
10-31-2007 18:19:14
Has anybody ever tried his or even given any thought to it. I like the power of the wd but prefer the ca controls and setup. Just curious, probly not gonna start tearing either one apart anytime soon. Mike
JMS/.MN
11-01-2007 10:33:51
 Re: wd45 engine into a ca in reply to Mike in Ohio, 10-31-2007 18:19:14
When the D14 came out, about 1957, it was touted as about the same hp as the WD45, but weighed less, and had smaller (26 inch) tires. Not good for a field tractor. If you could stick that in it would be simpler than using the 226, with it's inherent need for a frame to hold it. KISS formula-lol
02XLT4X4
11-01-2007 08:01:35
They did make several experimental C/B's with WC engines in them. There are pics in Norm Swinfields A/C book.
Jeff Z.
10-31-2007 20:30:23
I have faith in you if you really put your mind to it.
I have seen a V-10 Viper engine in a PT Cruiser.
Anything is possible.
Good luck on your project.
Dick L
10-31-2007 19:10:10
About any thing can be done with enough money and adapter plates. The blocks are different shape and widths where they bolt to the bell housing. I have a WC block and a feller stopped in one day and swore that he had a WC engine in a C. Said it bolts right in. When he left I set the block on end and set a C torque tube on the block and there was no way without major redesign and machining.
Bill(Wis)
10-31-2007 19:05:50
Try to wake up JMS/.MN. He might have an idea. old might know. I'll ask my old retired AC Supermechanic when I see him but he's hunting out in Montana right now.
JMS/.MN
11-01-2007 07:18:10
 Re: wd45 engine into a ca in reply to Bill(Wis), 10-31-2007 19:05:50
zzzzz zzzzz zzzzz zzzzz zzzzz z....
Bill(Wis)
10-31-2007 19:10:12
Thinking about it again, I think you'd be better off looking at a D14 or D15 engine. They had a torque tube design similar to the C and CA. WD/WD45 used a full frame design with the engine bolted into the frame.
Dick L
10-31-2007 19:12:56
 Re: wd45 engine into a ca in reply to Bill(Wis), 10-31-2007 19:10:12
The D-14 / D-15 will bolt right up. You have to use the CA flywheel.
