Oil pump
Cman
10-27-2007 14:15:31
1949 B Allis Chalmers
I have the oil pump removed and dis-assembled. The cover is grooved and scarred, as well as the pump rotor. This engine had almost no oil pressure when I tore it down. All the bearing, rod and mains look good. Is this scarring on the oil pump body cover and rotor cause for low oil pressure. If so any ideas for an oil pump rebuild kit or a new oil pump.
Thanks for your help. I am new with AC.
Dick L
10-27-2007 17:30:37
 Re: Oil pump in reply to Cman, 10-27-2007 14:15:31
The cover on the right is probly like yours. the cover on the left I re surfaced. The bad one here I cleand up on a surface grinder. When they are not real bad I have cleaned them up with a file until they are as smooth as the one in the picture.
third party image
old
10-27-2007 17:10:59
The scaring isn't because of low oil pressure but its the cause of it. It may have bad bushings in the pump or something else. I had an 8N not long ago that had that sort of problem sort of, it would loose prime but once primed it had around 40 PSI. So what I did was took the scored plate and used a flat surface and sanded out the scored areas and it now work just fine. Not sure if you could do that or not since I have never really look at an oil pump in a B/C
