wc shifter problems
DavidF
10-24-2007 15:25:45
Im new to repairing these;how do i remove the pin holding the shift lever in the tower,I have taken off the boot and snap ring.
wdTom
10-24-2007 17:47:05
 Re: wc shifter problems in reply to DavidF, 10-24-2007 15:25:45
If I remember there is a snap ring in the top, under the boot, inside the top of the casting, above the ball on the shift lever. After you take it out the shifter will lift out, and the pin you refer to which is also a key to keep the shift lever from rotating, can be pushed inward and will fall into the transmission where you will be fishing with a magnet for a long time to find it. Don't let it fall.
DavidF
10-24-2007 18:01:33
 Re: wc shifter problems in reply to wdTom, 10-24-2007 17:47:05
Thanks wdTom. I have the shifting tower on the bench.i have a spare shifting tower I am rebuilding.
Joe M(GA)
10-24-2007 17:22:16
David, the pin doesn't go all the way through, it's just a pivot.
DavidF
10-24-2007 17:53:17
 Re: wc shifter problems in reply to Joe M(GA), 10-24-2007 17:22:16
Thank you Joe. I found this out.Do I have to remove a shift rail to remove the bottom portion of the shift lever to remove it.Sorry for sounding so dumb .I bought a service manual which is pretty useless.I'll probably have more questions as I proceed please be patient.
Joe M(GA)
10-24-2007 17:58:56
 Re: wc shifter problems in reply to DavidF, 10-24-2007 17:53:17
If you get some long nose pliers you can reach in and turn the reverse lockout so it will come off, but it's a real PITA to get it back on. If you remove a rail watch for the spring and ball, they fly real nice and hide even better!
DavidF
10-24-2007 18:04:19
 Re: wc shifter problems in reply to Joe M(GA), 10-24-2007 17:58:56
Thanks JoeM for the info ,I appreciate the promt response.
