What Wheel for AC WF
John
10-31-1999 02:33:12
I have a 1938 unstyled AC WF, and need one rear wheel. Does the 24" pressed steel rim of the WF interchange with any other tractor? The rim bolts up with 6 lugs. Did Allis use a number stamp on their rims- I can't find one unless it is on the back.
Grandad
10-31-1999 04:21:20
 Re: What Wheel for AC WF in reply to John, 10-31-1999 02:33:12
The pressed steel 24" wheel was used on the WF from serial # WF-204 thru WF-1903 and on all WF industrial tractors. This information came from the Allis Chalmers parts manual for the WC, WF and W201 Power Unit.
GrandadsAC
10-31-1999 06:20:18
 Re: Re: What Wheel for AC WF in reply to Grandad, 10-31-1999 04:21:20
P.S.
This is the same wheel that was used on WCs from the late 30s and early 40s
John
10-31-1999 14:01:04
 Re: Re: Re: What Wheel for AC WF in reply to GrandadsAC, 10-31-1999 06:20:18
Thanks Grandad, Maybe I can locate a wheel since they were used on the WC also. After building the mad and carb, she cranks on the first turn of the crank after 20-30 years in the woods. Pretty good engine.
