Taller tire
Glider
10-24-2007 09:23:16
I have a WD45 with 13.6x28 tires, I want something taller. Any ideas about rims, and wheels? I have adjustable now.
Obsession
10-25-2007 20:19:57
 Re: Taller tire in reply to Glider, 10-24-2007 09:23:16
Some WD45's came with 16.9 28 tires. You can buy wider rims new and use your existing hardware.
We have one WD 45 with 13.6 38 inch tires. The rim centers are from a 6080. 34 inch wheels will also bolt on from a 6080.
Texas Denny
10-24-2007 12:09:41
My WD-45 has 14.9 x 28 on standard rims. These are considerably taller and look a lot better than 13.6 x 28. It will add two inches minimum to the height. I had 13.6 on my WD and it looked more like a 4" difference though I did not measure. Send me an email and I'll send you a picture with the 45 and WD together so you can see the difference.
02XLT4X4
10-24-2007 10:27:40
Not sure how much taller you want to go but 14.9-28 was a option from the factory. Most combine wheels are ea bolt on as well, I just got some 14.9-26 tires off of a Massey mounted and ready to go.
dej(jed)
10-24-2007 09:49:49
Some guys are running 13.6 x 38's on WD's. There are 38 inch pressed wheels available. Also some guys take the AC centers and fabricate their own 38 set ups by welding 38's on to the centers.
