WD 45 stuck in 1st gear
doorman
10-23-2007 19:40:30
Just bought a WD 45 wide front. It is hung in first gear. I will have to change the top cover, because someone welded the washer that holds shifter lever. Can I drill the rear welch plug on the first/second shifter rail and push the rail forward to get it back in neutral? I need to be able to get it in reverse to get it out of the barn it is in. Thanks, doorman
John (C-IL)
10-24-2007 05:54:28
 Re: WD 45 stuck in 1st gear in reply to doorman, 10-23-2007 19:40:30
The shifting forks slide on the rail so moving the rail won't do you any good.
If you can't pull the shifter, removing the transmission top is your only option.
Looks like you need to lock the clutch abd pull it out of the shed.
