D15 loader hydraulics - use traction boost?
Flat47
10-21-2007 17:00:13
I recently acquired a '61 D15, gas, with an A-C Model 0 loader. The loader runs off of the tractor hydraulics via the rear outlet by the seat. I can only get the loader to operate when the Traction Boost lever is all the way in the up/forward quadrant.
Is this correct? Seems to me that the loader should function with the Boost lever in any position.
Any insight?
-T
M Nut
10-21-2007 17:27:47
 Re: D15 loader hydraulics - use traction boost? in reply to Flat47, 10-21-2007 17:00:13
My D-14 is set up the same as your tractor and it makes no difference where the traction booster lever is set. Mine will get slow if low on hyd. fluid, but I don't know what the traction booster would effect regarding the loader control.
Rob Ward
10-21-2007 17:17:40
I agree with you and don't know why the traction booster would have any effect on the remote hydrolics. Is your pump healthy?
