What is the difference in a d17 series 3 and the 175 engine?
TORQUE13
10-20-2007 23:02:45
Can anyone help me? I would like to know the difference in a d17 series 3 and the 175 engine. Is it just the compression in the 175 engine higher to make more horsepower? Are the engine components interchangeable, because I would like to up the hp in my d17 engine. I was thinking that the cam specs maybe a little different in the 175. Like more lift or duration to make more power. Thanks in advance for any info. BRYAN SHARP
Skyhighballoon(MO)
10-21-2007 20:00:16
 Re: What is the difference in a d17 series 3 and the 175 eng in reply to TORQUE13, 10-20-2007 23:02:45
D17 gasser's all had 7.25:1 compression ratio, 1650 rpm rated speed and 1 inch carb. 170 gas had 8:1 compression, 1800 rpm rated speed and 1.125 inch carb. 175 gas bumped that up to 8.2:1 compression and 1.25 inch carb at the same 1800 rate rpm's. Mike
wolfman
10-21-2007 18:23:13
Both in gas versions had the 226 cu in engine. The most obvious difference is that the D-17 revved at 1650 rpm and the 175 at 1800. Probably a little different carbueration.
