Allis D17 Electrical system
Steve Wilkens
10-18-2007 19:25:10
Is the D17 6 or 12 volt, positive ground or negative ground?
steve(ill)
10-20-2007 18:19:42
 Re: Allis D17 Electrical system in reply to Steve Wilkens, 10-18-2007 19:25:10
all gas D17 were 12 volt positive ground from series 1 thru 4.
D17JIM
10-19-2007 07:10:03
There may be some early ones out there that aren"t, but I have never seen a D17 with original generater and battery set up that wasn"t 12V, positive ground. Jim
Chris B Ohio
10-19-2007 06:31:16
I know you are all talking D17's and I find it interesting that there are different responses. I have a '63 D12 Series II that is 12 volt positive ground from the factory. Evidently everyone believes they were all 6 volt. Why would that be?
Steve in NJ
10-19-2007 03:47:12
I believe D17 Series I models were 6V PG. Sometime in early production, AC upgraded to 12V PG, and the rest followed with 12V PG through the different series..
Steve@B&B
Steve in N.J.
10-21-2007 06:07:11
 Re: Allis D17 Electrical system in reply to Steve in NJ, 10-19-2007 03:47:12
I have a rebuilt starter motor for the D17 6V PG system Series I Gas which is an 1107466.
I also offer a wiring harness for the same, so the gas version did start off as 6V PG, and did change over to 12V PG sometime during production. I was going out of memory the first time, and started thinking about it and thought maybe that was the D14 I was thinking of till I did a little research. I'm still learning the "D" series yet...
Steve@B&B
JMS/.MN
10-18-2007 22:37:44
Interesting responses. My 1963 Series III is a 12 volt, positive ground. Started farming in '72 with a Series I, I think that was 12volt, positive ground. Don't think it was 6v, but definately positive ground.
wcman
10-18-2007 19:44:44
d17,s were 12 volt postive ground
wcman
10-18-2007 19:41:17
old
10-18-2007 19:38:36
If gas most likely 6 volt + ground
