steering hub seal
tmil
10-18-2007 15:48:32
does any one have an exploded view of the steering hub seals and bearings on a 49 allis b?
thanks
steve(ill)
10-18-2007 15:59:06
 Re: steering hub seal in reply to tmil, 10-18-2007 15:48:32
are you asking about the steering gear box below the gas tank? if the seal leaks , but bearing is o.k., many will pump it full of grease and last forever. there is also a bearing and seal on the from wheel hub. the alxe king pin area just has two bronze bushings inside the tube.
tmil
10-18-2007 16:47:48
 Re: steering hub seal in reply to steve(ill), 10-18-2007 15:59:06
I am referring to the felt seal, inner and outer wheel bearings. I bought new seals and bearings but I don't remember which way the seal faces, and also I don't know if there is a felt washer on what I will call the face of the seal.
JMS/.MN
10-18-2007 17:06:20
 Re: steering hub seal in reply to tmil, 10-18-2007 16:47:48
If a seal has any kind of cup in it, or an open end- that should face the fluid you are sealing in.
