D15 Series II missing
PS
10-29-1999 16:30:28
When you put in new or clean plugs, runs good a while then slowly starts missing. Plugs apparently are fouling out, black and sooty on electrode. Switched from Champion plugs to Auto-Lite but still misses after a while. Seemed to run smoother on Auto-Lites though. What's wrong? Could it be distributor or spark plug wire related? Put new wires on a few years ago. Would a dirty or mal adjusted carburator have any affect? Any suggestions would be appreciated. Thanks and have a nice day.
Norman Barron
12-08-1999 19:22:14
 Re: D15 Series II missing in reply to PS, 10-29-1999 16:30:28
My friend has an HD16. He needs info on the hydraulic system and pump. Who made it? We need a contact, if you could please help us. Thank you.
Hal
10-30-1999 16:52:05
In answer to the D-15 missing problem. Yes it could be dirt in the carburator or an adjustment to it that is causing the problem. This is what I would check first.You didn't say whether it smoked or not or if it burned oil so hopefully it is nothing serious.
Brian
10-31-1999 12:31:14
 Re: Re: D15 Series II missing in reply to Hal, 10-30-1999 16:52:05
If your tractor smokes, it will foul the plugs. Black smoke is too much fuel. Blue is burning oil. One thing that will help quite a bit is getting the engine up to temp. If it is running cooler that 180 degrees, it will foul plugs no matter what you use. I have had the best luck with AC R45's in a CA. I would avoid Champions like the plague. Some people discourage resistor plugs and suppression wires, however, since I switched to these, I have had no troubles at all and the wires even flap in the breeze. Hope this helps, Brian.
